Dominator
IL
Dominator
What is the throttle linkage supposed to look like on the Dominator? I'm trying to fix a brand new one for a friend - it brakes whenever you let off the throttle. So I looked at the brake setup, and I can't get it adjusted right. The manual is no help at all - no good pictures. Any help would be appreciated.
Re: Dominator
have you tried adjusting the throttle trim on the remote add a little more iddle to it by turning up the throttle trim
IL
Dominator
I've done that, it seems to help. I guess my real question is with that ball end - looking thing. There is a ball-end connected to a collar at the end of that rod, and there is a ball-cup (for lack of a better word, it's the same thing that's on the bottom of the shocks) that isn't on there. The two look like they would normally be connected, but when I put the ball in the cup, I can't get the linkage to work without putting a lot of pressure on the rod. It's probably impossible to follow this, sorry if I lost you.
