Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks
Reload this Page >
What's the faster truck with more than 22" you can buy with U$600 ?? Any brand.
RC Monster Trucks Discuss rc monster trucks in this forum
Old 12-16-2007, 10:03 PM
rafa26
Default What's the faster truck with more than 22" you can buy with U$600 ?? Any brand.
What's the faster truck with more than 22" you can buy with maximum U$600 ?? Any brand.
Old 12-17-2007, 04:54 AM
ttoks
ttoks's Avatar
Default RE: What's the faster truck with more than 22" you can buy with U$600 ?? Any brand.
LST2, MGT 8.0, savage 4.6 RTR, are all around 45 MPH out of the box (around the fastest RTR's are getting these day's), first two are 22 inches, savage is 20 i think.
Old 12-17-2007, 11:01 AM
Nick2618
Nick2618's Avatar
Nemesis/gst is bigger then all of them and it will get up to around 40
Old 12-17-2007, 11:02 AM
jombo
jombo's Avatar
mmt 25 inches long
Old 12-17-2007, 08:04 PM
bigairlife
bigairlife's Avatar
I like the size of the savage. It's big enough for hard bashing, yet small enough for small spaces and is more durable bacause it's smaller. Also, the savage is pretty much the most durable of the 3. MGT 8.0 is fastest stock, then LST2, then savage x 4.6 then MGT 4.60se! Go savage [>:] lol
Old 12-17-2007, 08:19 PM
rafa26
MGT 8.0 is 24" and i think it has the more powerful engine by far 8.0cc (.50ci) .
Old 12-17-2007, 08:20 PM
bigairlife
bigairlife's Avatar
But the it wil not rev as high
Old 12-17-2007, 08:35 PM
rafa26
ORIGINAL: bigairlife
Those trucks, (over 13.4lbs) needs torque a low rpm to start moving.
Old 12-18-2007, 04:11 AM
ttoks
ttoks's Avatar
you see, the problem with the MGT 8.0, is the engine is a converted helicopter engine, it might be torquey, but it makes little power, particularly being a side exhaust engine, the big engines are never as powerful as the specifically designed .28's because in an aircraft power is not the top priority, in an aircraft the engine must hold a tune to the tea even with weather conditions change, the engine must be able to rev at full throttle continuously, and most importantly the engine must be reliable, you can't have $2'000 worth of heli gear plummeting out of the sky because the engine fails.
even though the MGT 8.0 might have the biggest engine, i seriously doubt it being the most powerful or fastest monster truck, the CEN .46, which was made specifically for ground use with rear exhaust pulled .82 HP less then the leading .28 (ab mods picco .28 P3), and i''m sure all the experienced guy's here (particularly if they've dealt with planes and helicopters in the past) will agree with me.
oh and on a side note, torque at the crankshaft doesn't get you anywhere, it's how much torque at the wheels that matters, you can hav an engine making half the torque, but at twice the RPM and it will get you off the line just as fast, or quicker even considering the smaller engine is going to be lighter.
Old 12-18-2007, 07:04 AM
rclynx
rclynx's Avatar
This guy is a brute and stays together unless you jump and hit the ground WOT, then some of them shafts break cause its so damn big[&o] Fast it is
XTM Monster MT (MMT) 1/8+ RTR Monster Truck
The XTM Monster MT: Tough, Brutish, and HUGE! The XTM Monster MT (MMT) is one of the biggest and baddest trucks to hit the streets.
Specifications:
Length: 25" (63.5 cm)
Height: 12" (30.5 cm)
Width: 17" (43.2 cm)
Weight: 14 lb (6.35 kg)
Wheelbase: 16.5" (41.91 cm)
Tire diameter: 7" (17.78 cm)
Ground clearance: 4" (10.16 cm) with suspension extended.
Features:
Old 12-24-2007, 06:33 PM
Thai
TNX 5.2R
Old 12-27-2007, 12:04 AM
CrazyMento
All 1/8 has about the same top speed, 40 -45ish including HPI, Losi, AE, traxxas, CEN, ...etc
CEN GST 7.7 / Nemeiss 7.7 are the most torquey one and XTM MT ( not the newest one) actually do over 50mph and is the fatest one ( top speed wise)
