MGT8.0 OWNERS HELP ME. I am stuck with an axle pin !
Hi guys, that's my first truck and i just don't understand how to use the axle pin with the wheel nut. There's a place inside the wheel nut to accomodate the axle pin i think, but if if i put the pin there i will block the axle. I am lost, help if you can.
Thanks for your time.
CA
RE: MGT8.0 OWNERS HELP ME. I am stuck with an axle pin !
The pin goes in the axle hole.
The Wheel adapter slides on to the pin were you see the groove for a pin.
Then you slide the wheel on to the adapter.
Then the nut.
Then the nut.
dont mean 2 be ignorant but if your that stuck on the axle you hd better let your local hobby shop break in the motor for you. its a great powerful motor and im sure thats y u got it. no need to replace it yet. make sure it gets broke in properly by the right people and youll love the truck 4 a long time to come
Thanks for everyone who replyed to me here, the problem was that the hole was below the bearing and i couldn't see it.
Thanks guys.
Thanks guys.
