Need help with Axial .28
WA
i just got my Axial .28 engine for my warhead today. ok so the Axial .28 engine came with 2 insert thing to put in the carburator (there called reducers) Do i have to put those on or not??
WA
RE: Need help with Axial .28
Nope, they're to limit the air flow. I believe some Competitions have limits to carb sizes, but you will get the most performance without them...
What truck do you have? You're near by...
Like evader said you will get the most of the power without them. I also just got the axial and have 3 tanks so far. So far it seems like a great engine. Very easy to tune.
CA
Hey Evader read his post again.
ORIGINAL: chunkysause7
ON, CANADA
where can i get a flywheel nut for the Axial .28?
the axial is close to a match with the k4.6 from hpi.
http://www.hpiracing.com/products/en/86076/
WA
will either of these work??
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHMG0&P=ML[/link]
[link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNUM6&P=7[/link]
ON, CANADA
so yes they will fit
WA
What tool do you guys use to put the flywheel on the brass collet? I tried hammering it in and it won't go in all the way.
