warhead hub conversion
IL
i was wondering if anyone had converted thier warhead over to 17mm hubs so you can run diffrent rims and tires. if so what parts did you use. i searched but its came back empty on finding anything.
Thanks in advance.
Thanks in advance.
TN
RE: warhead hub conversion
I asked this same question in the Warhead thread. I found these on Tower Hobbies for the Savage, and they *look* like they'd fit, but I don't know. Can anyone confirm that these will work??
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMDB3&P=ML]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMDB3&P=ML[/link]
TN
ORIGINAL: SaVaGe MaN SS
yeah you can use them make shure you buy the nuts also
WY
The pro-line adapters are 23mm and will not fit on the evo cause its uses 8mm stub axles and the pro-lines were designed for the maxx trucks and revo and they use 6mm stub axles not sure thats the exact size but I do know they use smaller stub axles so the adapters wil be too small unless you drill them out which could be a real pain in the *****.
Get the savage x ss 17mm hexs and nuts and they should fit since the evo and savvy both use 8mm stub axles...
IL
i should of been a lil more clear im wanting to use this style of hubs http://www3.towerhobbies.com/cgi-bin...?&I=LXKZR3&P=7
do the savage cvds and axles fit the warhead?
TN
ORIGINAL: Clymer122693
Do you mean these?
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKSC1&P=7]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKSC1&P=7[/link]
[link=http://www3.towerhobbies.com/cgi-bin/WTI0001P?&I=LXKSC2&P=V]http://www3.towerhobbies.com/cgi-bin/WTI0001P?&I=LXKSC2&P=V[/link]
I saw those, but the thing i'm worried about is that the pins that come on the warhead are 2.2mm thick, while the ones in that kit are 2.5mm. The Warhead pins are also a little over 2mm longer than the Savage pins. I'm afraid I'm just going to have use witchcraft to get these 17mm Axial beadlocks on my truck!
IL
ya i talked to a couple guys last night to fit the 17mms your gonna have to find new dog bones and axles... the 23mm pro line hubs bolt right up though i just ordered mine today.
I ordered some stock Raze 17mm hex hubs, they fit using the stock pins that come with them. slightly file the backside of the hex so the pin lines up, and use the stock nut from the original warhead hub. I trial fitted one from my kid's raze and it looks like it will work fine.
TN
Does the drive pin fit on the warhead? The stock Warhead drive pins are 2.2mm and the ones that come on those Raze hubs are 2.5mm. Does that 2.5mm pin fit in the hole on the drive shaft?
just so everyone knows, the stock 17mm Raze hubs can be made to fit, and the pins fit perfect. Just file down the back side of the Raze hubs slightly so the drive holes line up, and ur good to go!!!
