RC Monster Trucks Discuss rc monster trucks in this forum
warhead with lrp spec 3 .28 pull
Reply
Old 01-12-2008, 08:08 AM
jbarton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default warhead with lrp spec 3 .28 pull
Anyone ever put this in your truck. I have one now ,it fits with a little bit of grinding to motor mount to clear the bottom left pull starter screw.And some clearancing for the pull to go through side of frame.I am having trouble finding the right flywheel with right thickness.I am trying to use the lightweight flyw from duratraxx but the stock flyw is to thick mine is .382and it looks like i need from a .24 min to .28 max at least with my bell which is .860. I have shim kit if i get one close enough. I have thought about the raze flyw since it was made for an sg crank i called and seemed no one there could read a dial caliper and told me they could not help and most flyw do not list thickness of it. i guess i will just order a bunch and see what works thanks for any info it will be appreciated
jbarton is offline
Old 01-12-2008, 01:06 PM
schlags62
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: warhead with lrp spec 3 .28 pull
I dont have any input as of yet but I am very interested in hearing what you find out. I also am working on putting the Z.28 in a WH roller. I might have to keep you in mind when I start so I can pick your brian
schlags62 is offline
Old 01-12-2008, 01:28 PM
jbarton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will put everything i had to do on here. It loks awesome bolted down in there i have a nova rc head and a set of there aluminum clutch shoes to. Think about the tires i lost 15.92 oz putting the tires off a smartech truck drilled the side frames all together ive dropped 23.45oz I can not wait until its finished i am making an order at tower hobbies tonight a flywheel i think will work and a shorter bell to try and fit something together
jbarton is offline
Old 01-12-2008, 05:16 PM
schlags62
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes if you dont mind keep a list of what you needed and what you used that would really help me since this will be my first replacement/motor exchange
