RC Monster Trucks Discuss rc monster trucks in this forum
warhead evo spur gear wobble
Reply
Old 01-15-2008, 08:20 AM
jbarton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default warhead evo spur gear wobble
Hello. I got this truck 1 1/2 months ago. And i noticed even when brand new the spur gear wobbles.The shaft does to. Did anyone else have this problem if so will they replace it? And does anyone make any gears other than 49 Thanks
jbarton is offline
Old 01-15-2008, 04:51 PM
Coadster67
Coadster67's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: warhead evo spur gear wobble
I dont own a warhead, but guess either the spur shaft is bent, or the bearing is gone.
Coadster67 is offline
Old 01-15-2008, 05:26 PM
motodude11
motodude11's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yea thats normal mines done that forever, as long as it works dont worry about it.
motodude11 is offline
Old 01-15-2008, 06:08 PM
jbarton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info!
jbarton is offline
Old 01-15-2008, 06:38 PM
Deftones123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thats normal, mine does wobble too and it runs fine
Deftones123 is offline
Old 01-16-2008, 03:13 PM
DoctorS
DoctorS's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's actually the clutch spring. I just finished repairing a Warhead for a friend, and both the old style clutch and the new clutch I installed wobbled. The clutch spring seats are not perfectly perpendicular to the shaft, and when you tighten up the clutch nut, the spur gear moves into position with the spring seat. To remove the wobble, I used my Dremel with a flat sided round stone. I ground the high side of the spring seats until the spring stood upright on a table. With the perpendicular seats now on the spring, the spur gear wobble disappeared.
Doc
DoctorS is offline
Old 01-17-2008, 08:24 PM
jbarton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks! doc. I did what u said and it fixed it except i used a 90 air tool with a small flat sanding pad . Your fix works great . that spring is qiute stiff . The shaft does not wobble now either THANKS!!! jbarton
jbarton is offline
