RC Monster Trucks Discuss rc monster trucks in this forum
monster gt, gpm arms
Reply
Old 01-20-2008, 06:00 AM
bashingozzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default monster gt, gpm arms
Iv just got a set of alum arms for my mta4 and im lost on what way they go on because they are a bit diffrent to stock items so i cant trn to the manual. So if any one has pics that would help alot.
Cheers
Dave
bashingozzy is offline
Old 01-20-2008, 08:22 AM
snowbl!nd
snowbl!nd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: monster gt, gpm arms
Did you get a new set of rollpins with the arms?
As you obviously can no longer screw the pins into the arms (as you can with the stockers or RPMs) you should have been given a pack of new pins which will probably be held in place with circlips. Other than that they should mount up exactly the same.
Out of interest why did you go with aluminium arms?
snowbl!nd is offline
Old 01-21-2008, 03:42 AM
bashingozzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got the pins, its just at the end of the arms they are diffrent as in they have a hole on the top of the arm(not sure for what) and now that iv put the wheels on i have huge toe in so im not sure if thats normal when upgrading to these arms. I use alum arms and parts on most of my cars as i find them alot stronger then stock items and plus makes the truck look tuff
Old 01-21-2008, 07:26 AM
snowbl!nd
snowbl!nd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The holes are probably intended for you to use grub screws to retain the pins. Toe-in would suggest the arms are shorter than stockers, but you should be able to counteract most of that by shortening the turnbuckles...
Good luck with the alum arms, i just hope that a big crash doesn't pass the stress onto other parts which will be harder to switch out...
Got a pic?
Old 01-22-2008, 05:44 AM
bashingozzy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im half way into building it, just waiting on rear and frount alum bumpers, titanium pillow balls then il be looking at buying a sport zurst ,alum diff case's and maybe a roll cage and if money is good il upgrade in the future to the pro 28 size motor but can i buy rods that i can adjust the toe-in?
ID:	857846   Click image for larger version
ID:	857847   Click image for larger version
ID:	857848   Click image for larger version
ID:	857849   Click image for larger version
Old 01-22-2008, 05:59 AM
scottywilkes
scottywilkes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
aha i see ya problem, the turnbuckles are meant to be mounted on the lower side of the knuckles and steering bellcrank, if u install them on the top it will put huge toe in on the wheels. Mount them on the lower sides and u will be fine
Also u adjust the turnbuckles by turing the shaft, the shaft is threaded into the turbnuckle ends, and when u twist the shaft it threads in and out of the turnbuckles, thats what the squared of area is for in the middle of the turnbuckle.
scottywilkes is offline
Old 05-18-2008, 03:52 PM
mike mta4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi i had very similar arms on my mta4 . i think the holes you are asking about are the ones on the end of the arm next to the pillow balls? they are threaded to clamp the arm tighter on the pillow ball thread to stop it undoing itself when your running . i still had problems with mine undoing so i put some nuts on the pillow balls and locked them up to the end of the arm .
mike mta4 is offline
Old 05-18-2008, 08:52 PM
Hardin Valley Magic
Hardin Valley Magic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those arms look good!! But my question is.... WHy so much fuel line rolled up???? Having the carb draw up and down around and around...Or is it to gain a little more fuel for longer run times in races... Just courious..
Hardin Valley Magic is offline
Old 05-19-2008, 09:23 AM
KRO
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would like to know also .
The MGT/MTA4 has a dual pickup fuel tank that will allow the truck to run when turned over .
Be careful landing jumps wiith those alloy arms , they will transfer impact energy too the diff cases and will rip the lower hindge pin out of the mount . (been there done that)
KRO is offline
Old 05-20-2008, 07:46 AM
scottywilkes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the later MGTs had the duel pickup removed, if u look inside the tank u will only see the lower brass pickup, they removed the 2nd pickup as it degraded and caused horrible airleaks which played havoc on your tune
