.25
PA
hey guys whats up i was just wondering if the force .25 from ofna will make the savage wheelie cause i want wheelies
you should be able to wheelie with the stock engine....Mine is completely stock and it wheelies right on its @$$ from a standstill with the engine running at 225....
Hey i have a .25 and a .26 and the stock i have the .26 in it now and that one pops right off the bat the .25 does the same
PA
hey thanks for the info cant wait to try it
PA
someone help i just put the .25 in my savage and it wont wheelie and i even tightened down my slipper clutch and it still wont even lift them off the ground i have a 14 tooth clutch bell and it just wont do it can some one help me
Stiffin up your shocks with some thicker shock oil.35 or 40 wt should do the trick.I read somewhere that the reason the savage doesn't wheelie is because of the suspension travel soaks up all power when you accelerate.I use 35wt in the rear and it will wheelie when it has enough traction the hyper21 likes to break the tires loose on just about all surfaces even with 40series road rage tires.......lol
GA
wheelieing is not something that happens all the time.
Under normal circumstances, you do NOT want your moster truck to wheelie. So if you want to get it to wheelie, you will have to change the sustension setup among other things.
A thicker wt schock oil will definitely help. But, this will COMPROMISE OVERALL HANDLING. Your truck will roll over easily and it will land a lot harder.
see if you can move anything around and get more weight in the back. That should help you wheelie easier.
ram
ram
NJ
what if u put a .25 in a rs4 3 rtr it wouldnt fit would it
yeah i put heavy duty in all four and started her up they snap when i hit the gas on grasses so i put universal in everything haven't broke yet
Previous Thread
Next Thread
