RC Monster Trucks Discuss rc monster trucks in this forum
radio battiers
Reply
Old 04-16-2003, 04:32 AM
17champ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default radio battiers
Hey guys I want to put a 1700mah 6v battery pack on my t-maxx.
Any body done this?will the reciever handle this.
17champ is offline
Old 04-16-2003, 05:28 AM
dainjarouz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
as long as the voltage is between 4.8 and 6v, mah doesnt really matter
dainjarouz is offline
Old 04-16-2003, 08:44 AM
adeoliver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will work fine, I use to run 1800mah 6volt Rx packs in my trucks, and never had any problems, basicaly all that number means is better run time with a little more punch, kinda like a bigger fuel tank with a leaner mixture.
adeoliver is offline
Old 04-17-2003, 02:34 AM
packfan88
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ive found out the voltage on a "6.0 volt" pack fomr somewhere like tower hobbies actually puts out higher than 6.0 volts.
freshly charged it come out closer to 7.0 so in any event ........ditto you can use it with out trouble in your rig.
homemade tip
you can take your existing battery pack and just "add-on" a 5th AA cell to give you the same results.
packfan88 is offline
Old 04-17-2003, 05:24 AM
17champ
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
THANKS GUYS.I HAVE FLOWN RC PLANES FOR 15 YEARS AND USE THE LARGER PACKS BUT THIS T-MAXX RADIO SEEMED CHEAP,SO I WAS NOT SURE.
17champ is offline
Old 04-17-2003, 12:59 PM
savageforce
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mah is only a capacity rating...the higher the number, the more "juice" it'll hold. The voltage output is what you need to be concerned with. However, be careful when you charge it. Keep the charge rate at 1amp. Any higher will only shorten the life of the batteries, as well as your run time.
If you're running an electric truck, then you charge around 3-5amp (depending on the quality of the batteries). The higher the amp charge, the more "punch" the batteries will have, but they will discharge quicker.
Being that you don't need to worry about "punch" with the RX battery, keeping the charge rate at 1amp will insure you get a long run time out of it.
I have 1600Mah AA Sanyo's from Ballistic Batteries and I can go ALL day with my Tx and the voltage will barely drop! Good batteries make a world of difference.
savageforce is offline
Old 04-17-2003, 03:36 PM
JeDi_MaStEr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey not to switch subjects..however...madforce83..you have the ultimate workshop.kudos to you, i thought I had a sweet setup in my home office, but man you take the cake!!I am green with envy
JeDi_MaStEr is offline
