RC Monster Trucks Discuss rc monster trucks in this forum
Tmaxx help
Old 02-01-2008, 10:17 PM
jessemxt
Default Tmaxx help
I have a used Tmaxx 2.5r and I threw a extra 2.5 engine in but the crankshaft is almost touching the transmission. Do they make shorter crankshafts for those or am I doing something wrong? Hey I posted this in the Traxxas forum but to no avail I just want some opinions on what you think. I got this tmaxx used cheap.
ID:	867536   Click image for larger version
ID:	867537   Click image for larger version
Old 02-01-2008, 11:42 PM
iamnot
Default RE: Tmaxx help
you sure you used the right mounting holes?
what did the 2.5 come off of?
i've got a 2.5 and a 2.5r and mine are identical - except for head color.
what happened to the carb?
edit
just noticed a couple things in the pics
the blue head means that engine is a 2.5r
it looks like there is a clutch adapter nut on that crankshaft - see if it will screw off.
Old 02-02-2008, 01:46 AM
LosiMadMan
Take a dremel and cut it of leaving the threads.
Old 02-02-2008, 02:41 AM
jessemxt
I have it in the right mounting holes, The carb is off a old revo and I assume it somehow hit the spur gear, I am not sure if it is the 2.5r engine as it was in a bag when I got it. Do you think the chassis is bent one of the chassis braces is cracked.
Old 02-02-2008, 11:17 AM
Jeckler
Is that a Maxx trans? Doesn't look like either of mine.
Old 02-02-2008, 02:50 PM
jessemxt
Yeah it is a Tmaxx 2.5r I looked on the Traxxas website and everything looks the same.
Old 02-02-2008, 08:40 PM
Jeckler
Looks more like a 3.3 tranny, not a 2.5
http://www.traxxas.com/products/nitr...x25_tranny.pdf
http://www.traxxas.com/products/nitr...x33_tranny.pdf
Old 02-02-2008, 09:22 PM
jessemxt
Here this is a 2.5r the 3.3 and 2.5r are almost the same.
Old 02-02-2008, 10:10 PM
Jeckler
You really don't see the difference?
Your pic is a 3.3
Old 02-02-2008, 11:49 PM
jessemxt
Well I got a Tmaxx 2.5r manual with the truck. But in any case it still doesn't fix my problem. I can see on the transmission it looks like something rubbed.
Old 02-02-2008, 11:55 PM
jessemxt
Here is a pic the camera wont focus very good
ID:	868638   Click image for larger version
ID:	868639   Click image for larger version
Old 02-03-2008, 01:31 AM
Jeckler
OK, I'm an idiot. When I surf to the Traxxas site, I only see the 3.3 and the "Classic" 2.5. After finding the actual page for the 2.5r through a Google search, I see what you're talking about, that the tranny is the same as the 3.3. My bad.
Maybe the cranks are different between the two as well.
