RC Monster Trucks Discuss rc monster trucks in this forum
Trx 2.5 Vs Ofna .25
Reply
Old 04-18-2003, 02:23 PM
joe78586
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Trx 2.5 Vs Ofna .25
Some questions
Doese the .25 have alot more power than the 2.5?
How will the t-maxx react with the .25 on it?
Do I need to buy a new flywheel or will the the .25's cluchbell fit?
Also,
I have the 2.5 but broke the rod and the piston has a little crack at the very bottom. Do I need to replace the piston?
If someone has one that they can sell me I will buy. Or where can I buy just the piston without the sleeve?
thaks for your replies
joe78586 is offline
Old 04-18-2003, 02:59 PM
Avalanche
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With the light weight of the maxx and the 2.6hp rating and the super torque of the Force engine, I would say you will have a tough time keeping it on all four wheels. Just so you know, I dont think the 25 will drop in. You need the .21 conversion kit.
Avalanche is offline
Old 04-18-2003, 03:23 PM
i8tweety
i8tweety's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you snapped a connecting rod and damaged the piston, you will need to replace the piston and sleeve as they are matched sets.
i8tweety is offline
Old 04-18-2003, 03:24 PM
i8tweety
i8tweety's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sirio sells upgrade internals for the traxxas 2.5. If you decide to rebuild and wanted more power, that's an option.
i8tweety is offline
Old 04-18-2003, 08:51 PM
RKM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or you can go and buy a sirio .18 and sell me your broken 2.5. Just thought I would put that out there.
RKM is offline
Old 04-18-2003, 09:11 PM
adeoliver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well to be short there is no compairison to a small block and big block, but you should know that!! Your on the maxxtraxx forum correct? Anyways You must replace the piston and sleave, as well as the rod in your broken 2.5. There is no sence in running with a broke piston.
As for putting the .25 in your maxx you will need a .21 conversion, but the 2.5 clutch assembly with fit right on the engine, the only thing that will be needed in that place is a 1/8th clutch nut, do to the fact that the shaft is to big for the 2.5 clutch nut!!
adeoliver is offline
Old 04-19-2003, 01:19 AM
joe78586
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How much would you give for the 2.5 rmiller?
I know I need to upgrade to a .21 conversion but I was planning on making my owen parts and just buy the engine and mabey the mount.
What cluch nut, do you mean the cluchbell?
i8tweety What you are saying is that with the sirio piston/sleeve I will have more power than the stock piston/sleeve?
Doese anyone have a piston/sleeve or a connecting rod sitting around that you can sell me.
thanks
joe78586 is offline
Old 04-19-2003, 01:52 AM
RKM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rebuild is around $80 or better I believe. You can buy sirio internals and put it in your 2.5 and get more power. But from what I am told it will not put out as much power as a sirio .18. Ohh and the sirio internals are over $100 because you have to get the crank, rod, piston, sleve. The sirio sells for $185- $200. i AM TOLD THAT IS THE WAY TO GO.
RKM is offline
Old 04-19-2003, 02:00 AM
joe78586
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
then what do you want a 2.5 for if you say the sirio is better?
joe78586 is offline
Old 04-19-2003, 02:02 AM
Isphius
Isphius's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the .25 is almost twice as big displacement wise as the 2.5 It should easily lift the front wheels, at pretty low throttle. You might want to get upgraded diffs and drive shafts though.
Isphius is offline
Old 04-19-2003, 02:05 AM
RKM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just want to play with it. It's no big deal to me. You can keep it or sell it to someone else. I just figured You could get a little cash toward your new setup and I could tinker with something. The sirio is definately more powerful (from what I've read) I will most likely get one soon. I don't want to get into changing everything into an 1/8 scale truck. I myself cant wait to see the new associated truck. I might get one of them as well.
Let me know.
RYan
RKM is offline
Old 04-19-2003, 02:42 AM
joe78586
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I had the money I would buy it but right know I don't have any and I think I will just have to wait and see which one comes first.
joe78586 is offline
Old 04-19-2003, 01:37 PM
RKM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Joe,
I found a NEW TRX 2.5 on ebay for $120. It has never been run. It is almost the same as the one that comes in your max but the crank sticks out a little longer. If you grind it down a little to the length of you 2.5 you will have a new engine.
Here is a rebuild kit for around $40
http://cgi.*********/ws/eBayISAPI.dl...category=34063
Here is the 2.5
http://cgi.*********/ws/eBayISAPI.dl...category=34062
hope you see these in time
RKM is offline
Old 04-19-2003, 02:17 PM
grampi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Putting that .25 in your Maxx is way too much power. You won't be able to use it all. BTW, the Force .25 makes 2.39 hp, not 2.6. If you want to overpower your Maxx, you can do it by just dropping in a Sirio .18. It's a direct drop-in replacement for the 2.5. Installing a big block requires a whole bunch of other mods.
grampi is offline
Old 04-19-2003, 04:58 PM
joe78586
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about the Yokomo .18 RX engine?
How much power doese this one have?
If it is as much or more than the 2.5 I might get that one.
But I don't want an engine with less power than the 2.5.
Right now what I really want is to get my maxx running again.
If someone has a used sirio .18 or sale please post.
joe78586 is offline
Old 04-19-2003, 06:24 PM
adeoliver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks
No the clutch nut and clutch bell are 2 totaly different things. You will need a "1/8th CLUTCH NUT" to run the stock flywheel, clutch, and clutch bell on a .25 or any other big block engine!!
Stock clutch nut:
Ofna sg shaft clutch nut(1/8th)
Ofna Threaded shaft clutch nut(1/8th)
Old 04-19-2003, 08:03 PM
joe78586
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh I see.
And I guess I will also need the a new exhaust and header.
I think I am just going to go with a drop in.
What about the Yokomo .18 RX engine?
Is it a drop in?
I found one with less than 10 tanks on ebay that is currently for 49.00 and thought I could use that but I need to know if it is a drop in and if it has equal or more power than the 2.5. OH, and it has a carbon fiber boost bottle.
joe78586 is offline
Old 04-19-2003, 09:57 PM
grampi
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've never even heard of that engine. I wouldn't even mess with it. Just get the Sirio. That thing is guaranteed to kick *****!
grampi is offline
