This stinkin' head is still leaking!
I don't believe it, even after my friend put this head in a lathe and trued up the glow plug sealing surface, it's still leaking compression. You can see the fuel bubbling out arond the glow plug when it's running. I don't get it. Even if I have the wrong glow plugs for it, they are the right thread size and they should seal. I have a Traxxas glow plug on order from Tower, so I guess if it leaks with that plug installed, it's a head problem. I just don't understand why it would still be leaking.
dang, that sucks. if it still leaks you can order a new and better cooling head for the 2.5 made by someone other then taxxas. cant remember who makes them but they are pretty cool.
Grampi, are you using the Traxxas plugs? If you want to try some other ones, I run OS #8. I also hear the OS #3, are the same plug for the most part, just less expensive. I also hear the McCoy MC-59 are a decent plug. Try them out, maybe they will work better....
Another thing you could do is to seal the plug with blue Locktite or high-temp GE silicone.
As mentioned earlier, try an OS or MCcoy plug. Maybe the Traxxas plug that you have was from a bad batch. Both OS & MCcoy are about the highest quality plug you can get.
Grampi didn't you just get that truck?If so just call traxxas and cuss them out and they'll send you a brand new one.
I decided to order a Nova Pro head for my 2.5. I know it's more expensive, but who knows how long it's going to be before Traxxas decideds to get off their dead *****es and ship some more out the distributors/retailers. I might be waiting all summer before I can get one. besides, the Nova cools a lot better than the stock head.
