RC Monster Trucks Discuss rc monster trucks in this forum
Savage Transmission Screw
Reply
Old 04-27-2003, 03:26 AM
beardking
beardking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Savage Transmission Screw
Hey guys, I know that you Savage Freaks out there can answer this for me. I have the Savage that every one loves so much and I had to take out the transmission (and just about everything else) so I could replace the brake and now when I push the truck back it'll go back, but I have to give it a good bit of force. I can't remember if it was this tough to push back before or not. I've tightened the infamous tranny screw and that doesn't seem to be making a difference. Can you guys tell me what might be causing it to be difficult to push back? Or is this normal. I hate that none of the LHS's around here know jack crap about Savage's. Living in Texas I think that it's a requirement to only know about Traxxas stuff.
beardking is offline
Old 04-27-2003, 03:49 AM
br052602
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the best way is tear it completly down and put it back together
for real: stick a screw driver in it and pry it back down but make sure the trany mounts go under neath the motor mounts ..
br052602 is offline
Old 04-27-2003, 03:51 AM
beardking
beardking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
br052602 - what am I supposed to be putting a screwdriver in and prying back down? I'm not sure what you are referring to.
Old 04-27-2003, 04:05 AM
br052602
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you have to pry on the ladder chassy just enough against the tranny so it can be pried back down, and yes it is normal to have the problem.
br052602 is offline
Old 04-27-2003, 04:31 AM
Rex2342
Rex2342's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you say push it back what are you refering to? Do you mean roll the truck backwards?
Rex2342 is offline
Old 04-27-2003, 04:55 AM
beardking
beardking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rex, yeah, just giving it a nudge backward doesn't work. I have to actually give it a good push to get it to move and once I stop pushing it back it doesn't roll on it's own like it would going forward.
Old 04-27-2003, 05:00 AM
Rex2342
Rex2342's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try backing of the screws that hold the brake on 1/4 to 1/2 turn and see if that helps any also maybe check your gear mesh on the spur for any binding sometimes when I take out my tranny I need to re-adjust the engine mounts screws
Rex2342 is offline
Old 04-27-2003, 05:06 AM
beardking
beardking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Rex. The brake is plenty loose, but I'll take a look at the mesh on it. Unfortunately, I don't know too much about these trucks yet (I normally fly planes), but hopefully I'll get the hang of it soon. How are you like that GPM brake hub? That's what I threw on mine.
Old 04-27-2003, 05:15 AM
Rex2342
Rex2342's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's pretty sweet and is holding up fine to the new double brake system.I forgot to ask you if the you have a NEW reverse module or anything?When I put mine in it went fine forward but kinda stuck a little bit going backwards after a few times running in reverse it stopped and rolls fine in both directions.
Rex2342 is offline
Old 04-27-2003, 05:27 AM
beardking
beardking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, I haven't added the reverse module yet. Still working on going forward consistently right now. Can't get the blasted thing tuned in just right. everytime I try to start it, it'll start up but die almost immediately. Getting on my nerves. As soon as I can, I'm going to take it to the LHS and get the Guru's to help me out.
Old 04-27-2003, 05:31 AM
Rex2342
Rex2342's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
if it's dieing when you give it throttle it might be getting to much fuel.Try turning the low speed needle clockwise 1/8 turn and check the carb to see if theres a 1mm gap when fully closed.
Rex2342 is offline
Old 04-27-2003, 05:40 AM
beardking
beardking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, actually, sometimes it'll wait until I give it throttle and then other times it'll start and by the time I make it my TX it'll die.
Old 04-27-2003, 05:46 AM
Rex2342
Rex2342's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thats frustrating.You think it's ready to go and then it dies.Does it run ok when you've driven it for a while or does it still die when it's sitting?My stock engine and my 8port do that sometimes but I just blip the throttle until I can get it to the road and it runs fine once it warms up.Sometimes I even have to give it 1/4 throttle while I'm starting it before it will fire up.
Rex2342 is offline
Old 04-27-2003, 05:57 AM
beardking
beardking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The last time I actually ran it, it ran fine. It was a huge pain in the A** to get started, but once I got it running, it was fine. But since then I haven't been able to get it to run long enough for me to set it down off the table in my garage and drive it outside. I know that I just don't have the tuning right, but it's definitely been getting frustrating. Might not be so bad if I had the Jump Start for it so I wouldn't end up with so many blisters every time I try to run it.
Old 04-27-2003, 06:08 AM
Rex2342
Rex2342's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah....electric starts are nice I wonder if that will work on my 8port.HPI says it'll work on the force .25 but i'm not sure if it's the same bolt pattern.It took a week for the blisters to go away after I broke in my Savage and after 2 months I had them again from the new engine..lol
Rex2342 is offline
Old 04-27-2003, 06:15 AM
beardking
beardking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, that's why I'm in no hurry to upgrade to a new engine. of course, I need to get this one fully broken in. Well, thanks for the advice. I'm heading to bed now.
