throttle sticking!!
throttle sticking!!
I just got done tuning my savage and now the motor will stick wide open and the truck just takes off full blast. How can i stop this?? Did i cause this by adjusting the needles on the carb??
Banned
Did you adjust the idle screw??
If you did that will make it run like that! This is the screw that when you turn it in will open the throttle up. You supposed to use this to set a good idle and not for tunning! That what the high and low speed needles are for!
