savage tuning help
My Feedback: (13)
savage tuning help
i tried adjusting the hsn and lsn nothing changes ..i remember my lhs adjusted the msn..do i need to touch it too then?cuz what ever i am doin its not helping ..it came back to were its hard to start and wont idle long..when i broght it to my lhs..he tuned it but then my rdlogics pipe came in the next day..it started to not start right away again ..does the hsn and lsn should have the same adjustments like if my hsn is 3 1/2turns out should i do same with lsn or i can put my lsn like 3turns or 2 1/2 turns,can u pls help i spent 50 bucks past 3 days ..1st tune up 10 bucks then my screw set on tranny were loose so i brought it again to be fixed..30bucks + 5tip for each visit..i cant do my tuning right..how can i succesfully do it..
savage tuning help
LSN low speed needle
hsn high speed needle
Idle screw
Now what is this other screw your abbreviating?
First, my hsn is at 4 turns out (I'm in New Orleans, yours should be further out, a good bit further). Make sure your hsn is set first, make sure your transmitter doesn't mess with the engine idle.
And when setting the lsn, make sure the idle screw is far enough out to keep it running. Also when you start your engine the first run of the day, loosen the plug and start it, this makes it way easy to start, leave the igniter on it till its warm!
CYA
Idle screw
CYA
savage tuning help
The Savage has a 3 needle carb.The mid range needle should stay where the factory put it witch is flush,the HSN should be backed out 3 1/2 turns and the LSN should be flush also.Then try to start it and tune it .Adjust the HSN first and then do the low.If the truck won't start try leaning the LSN 1/8 turn until it starts then tune the HSN until it runs good at full speed then adjust the low speed for acceleration.
My Feedback: (13)
savage tuning help
how come the guy at my lhs turned that needle (mid range needle) i didnt stop him cuz i know he knows what he is doing...anyways i tried to tune it but when its idling its sounds like it wanna stall then come back up it kept on doin that for like 3x then it stalled..and mine is hrd to start after you run it (when the engine is hot) i have to wait for it to cool down..i never had the chance to restart cuz the old lady next to my apartment came out cuz of the noise..
savage tuning help
I hope its not your engine. My savge did the same thing and it was the piston and sleeve hardly any compression. I didn't even have a gallon thru it it was only 3 weeks old. So now I have a piico .26 ordered.
savage tuning help
The savage's do not like to start when hot. Let it cool off. Go back to the factory settings, and start there.
RN
RN
Originally posted by badboy2
mine still have strong compression its just the tuning that i cant get right ...
