MGT Toe-In problem/feature? Help!
GA
Ok, I just finished installing the RPM arms on my MGT, and I have come across something that is either broken or that I never noticed before.
When the truck is off the ground, and the suspension is all the way at the lowest point, all the tires have extreme Toe-In. When the truck sits level on the suspension, the Toe-in straightens out and the tires face perfectly forward.
Did I mess something up or did I just never notice the fact that the tires Toe-In at maximum bottom extension?
Bryan
Bryan
WA
RE: MGT Toe-In problem/feature? Help!
If all the tires are doing it, then you may have the turnbuckles on the wrong side of the knuckles. They should be mounted under the knuckles.
Those are knuckle problems though, so if it just started after the RPM's were installed, I'm stuck...
