Driveshafts + Axles for my aftershock
My Feedback: (54)
I have to ask cause iam not sure if these will be a direst fit for my aftershock.or what do i need to change the asles ove to the 17mm drive
http://cgi.ebay.com/LST-2-Team-Losi-...em370135795931
RE: Driveshafts + Axles for my aftershock
No, those are for an LST2 which has larger spindles. I am not even sure that the LST2 spindles will fit an Aftershock/LST 1. I think by the time you get all the parts necessary to upgrade the axles, you're so close to spending as much as the LST2 upgrade kit you might as well just get that.
My Feedback: (54)
http://www.amainhobbies.com/product_...oducts_id/6409
amain hobby has the kit , i just want the axels for my mega baja witch is the same as the aftershock.
ON, CANADA
The Upgrade kit is one of the Best hop ups you can do to the Aftershock/Ram Trucks...... Here's a Thread showing the Difference's in the Parts.....
Difference's between the LST1/Aftershock & the LST2
My Feedback: (54)
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXNWR8
the kit would be good if your heavy into raceing and bashing the heck out of your truck, but some people like to run the 17 mm rims and the link here is a cheap way to goto the 17 mm rims to.
ON, CANADA
Those still use the Same Small Nut from the 14mm hex's...... These are the Way to go (if your not doing the Up Grade Kit) http://www.amainhobbies.com/product_...ducts_id/11588 (may have to drill them just a Little to fit)
