RC Monster Trucks Discuss rc monster trucks in this forum
Savage Tuning Question
Reply
Old 06-10-2003, 03:56 PM
Justintoxicated
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Savage Tuning Question
Well i broke in my savage with the factory settings, After about the 7th tank I decided to tune it a Bit.
I leaned both LSN and HSN by 1/2 turn. The manual says between 2.5 & 3 turns after break in.
Well after a couple tanks of gas more (2 or 3) I was hitting second gear pretty nice, there was no bog and it seemed pretty tuned!
Now I put on a motosaver air filter and fuel filter and I feel It may need some richening up, but the manual says between 2.5 & 3 turns, and Im already at 3 turns. Is the manual takeing the stock air filter into consideration? I left it alone my first run, and the engin ran a bit hot, and it bogged slightly after ideling every now n then. So Im guessing that I should probably lean the LSN and ricen the HSN a little past 3 turns due to the new filter?
Is it ok to go over 3 turns rich?
Justintoxicated is offline
Old 06-10-2003, 04:25 PM
Legendary
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default It can take some figuring!
From one day to the next you may have to re-tune your truck! From what I have read about the Savage on this forum you should leave the LSN alone and only lean out the HSN! I think it was Unstable that said "If I turn the LSN 1/8 of a turn in either direction from stock it does not run right"!
Legendary is offline
Old 06-10-2003, 05:20 PM
Justintoxicated
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
maybe i will richen it some more then, but it was working perfect at 3 tuns out, opposed form stock 3.5
Old 06-10-2003, 05:47 PM
Alteramod
Alteramod's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well really after break just adjust it to where it runs good without over heating. So if you find that richening is working then do it....
Alteramod is offline
Old 06-11-2003, 03:53 AM
Justintoxicated
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what is that article about reading the glow plug? I richened it some and it ran fine, a little cooler. Not sure how to tell if the LSN is tuned or not. It sounds like it idles high, but im new to nitro so i don't really know.
