Is This A Bad Idea?
Is This A Bad Idea?
I was thinking about removing the head on the savage and squirting some artic silver ceramique thermal compound on the engine where the head mounts, then re-bolting the head on. I figured it should pull more heat away from the engin then, so the head would get hotter but the engin would get colder.
Good idea ? Bad idea?
Is This A Bad Idea?
I don't see how it could hurt anything. Unless the head-to-block surface is used to seal the combustion chamber, then you might run into problems. I don't know if it would make that big of a difference though...
Is This A Bad Idea?
cool, if i ever remove the head ill give it a shot, Not sre it would make any difference, my friend said there was no gasket and from the looks of it there is one, Still, it might help some.
