Savage Throttle/Brake Linkage
Well this is killing me, for some reason I am having a hell of a time getting the linkage to work properly. I can either get lots of brake and 3/4 throttle or full throttle and no brakes. I can't seem to find that perfect in between. Is there a better servo saver setup than stock that anyone is using. Maybe I'm just missing something. Any thoughts would be appreciated.
You should adjust the servo saver so that throttle operation is optimized. The brakes are more easily adjusted.
You can replace the tubing on the brake linkage with a longer piece if you need more grab. Also you can loosen the set screw and drop the brake linkage arm (the vertical piece) a few mm or more. Be careful though you don't want too much...it will flip over real easy.
Previous Thread
Next Thread
