“Tire vs Rim” Removal is a real PITA! Do we need a better solution?
TX
Come on we all want to hear your success stories and your screw-ups [:@]
I know heat will work if you used CA glue Be careful toooo much heat will screw up chrome rims I know for a fact [:'(]
I also know debonder will work if you used CA glue
Stubborn wheels debonder + heat
Acetone will also work better than debonder on CA glue Will also work on Super Glue just not as well Super Glue is a pita it takes a lot of patience.
If you use acetone make sure it's compatible with your rim
WY
RE: “Tire vs Rim” Removal is a real PITA! Do we need a better solution?
I've always taken my tires off the rims by poppin them in the oven at 350f for 15mins works like a charm and only had issues with one set of chrome rims and that was a set of TRX split spokes, just left a bunch of little dots on the rims.
ORIGINAL: Clymer122693
