RC Monster Trucks Discuss rc monster trucks in this forum
tmaxx problem
Reply
Old 06-21-2003, 03:38 PM
ptimer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default tmaxx problem
i have a problem with the tmax i have checked most things fuel pipes petrol filter etc it is mainly to do with when i brake it cuts out i have got the mixture needle set at factory settings and i have to turn up the throttle trim to open the carb so it will start can anybody help me out it would be appreciated.
ptimer is offline
Old 06-21-2003, 03:59 PM
h22a4
My Feedback: (50)
h22a4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check the idle adjustment screw. You probably have your idle set to low.
h22a4 is online now
Old 06-21-2003, 04:29 PM
Dlock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take the air filter off, and look down the carb. There should be a 2-3mm gap in there. If not adjust the idle screw until there is....
Dlock is offline
Old 06-21-2003, 04:39 PM
ptimer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default tmaxx
when you say idle screw do you mean low speed needle because ive turned that and it doesent seem to move can i adjust the arm that connects to the carb
ptimer is offline
Old 06-21-2003, 04:51 PM
ptimer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks
ptimer is offline
Old 06-21-2003, 05:04 PM
Dlock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look at your manual. There are 3 different screws. One is the HSN, one is the LSN and there is an idle screw. It's on the opposite side of the LSN up near where the air filter attaches. Look through your manual it should show you exactly where....
Dlock is offline
Old 06-21-2003, 05:17 PM
ptimer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks alot
ptimer is offline
