truck kicks off at full throttle.
my truck runs fine up to about 3/4 throttle it will kinda stutter and full throttle it will completly cut off. i thought it was running lean so i adjusted the carb for prob a hr trying to get it right. it still does the same thing lean or rich with no improvement. i changed out the glow plug and the glow plug wire and tried a new tank with still no improvement. all the fuel lines look intact. sometimes when it idles it kicks. so does the problem have anything to do with the transmission? im pretty new to this so any help is very apprieciated. thanks.
oh my truck is a t maxx 2.5
RE: truck kicks off at full throttle.
It sounds like you are getting to much fuel in the carb, Try making adjustments using the remote control. Reduce the opening of you card to 1/16th. Do this while it is running. Remember when you make any adjustments to a carb it takes a while for it to get use to the adjustment. It has nothing tom do with the transmission. I got a Redcat earthquake that I was tuning today, and at 1/2 tank it started to spur, mess with the remote a little see if that works. I also have a traxxas that use to do the same thing. patience in adjusting will eventually fine tune the engine.
