hyper 8 port help
My Feedback: (13)
hyper 8 port help
i just installed the 8 port on my savage...man that pullstart killed my hand..i got cuts on knuckles, palm...the pullstart is too short to reach ...now i run it idle for like 3 tanks..so next is oval run 1/4throttle and 1/2 throttel ....now how do i set my needles for tuning..the manual doesnt say in there..or i just dont know if they are specifying tuning the lsn when they say 3 1/2turns out from flush...should i lean it or richen the hsn..after all the break in what is the desirable setting..pls help
NY
hyper 8 port help
put the hsn 2 3/4 from the buttom. i never touched any other needle and my 8 port is awsome. watch the temps though.i stay below 250 all the time, but i have the nova cooling head
My Feedback: (13)
hyper 8 port help
u mean close hsn and turn 2 3/4 out?how did u resolved that pullstart man its to tight worst than flooded..if i just took pic a while ago u could have seen blood form my knuckles on the cooling head..would that eventually go...and also when i try to run it oval its bogging down is that normal after the 3 tank idle..and with that thing how would u know if u flooded it..
hyper 8 port help
The pull starter will get easier to pull...after time. Plan on breaking them too-they are hella weak. And i know what you mean, its hard to reach the pull starter in the savage, there isnt much room back there. I think i might buy the hot bodies extended chassis later on. It gives about an inch more room back there, so pulling is a little easier...
hyper 8 port help
Put in a piece of fuel tubing or something.. so it doesnt go down all the way.
That way you dont have to touch that hot head every time you have to pull it.
You can also make a wire twisty holder.. like they have in lawnmovers!
ram
ram
My Feedback: (13)
hyper 8 port help
how long is that time ...ram nice idea too i am thinking of what i could put
If it is,
Anything like the .25 it took me about 3/4 of a gallon before it loosened up a bit! It is still pretty tight but, it starts in 1-2 pulls now so not a big deal!
NJ
hyper 8 port help
my 8-port has about 10 tanks and the pull start only loosened up a little. For the first few times i started it i used a rubber wheel electric starter for an airplane. It works great on the monster pirate. Plenty of power and rpms, but not much torque. my old thunder tiger 90$ engine could pull the 8-port powered truck up a hill.
My Feedback: (13)
hyper 8 port help
you guys are right now i can at least pull it a little bit to get a grip and 1 pull it starts is that for life?i hope its like this ..and when it bogs down cuz i never touched needle yet ..do iclose it and open it again?if yes how many turns out or should i adjust it clockwise 1/8turn from break in setting
hyper 8 port help
Alright fellas for those that absolutley hated me for destroying my .21BB i've stopped and I've got my New 8port on my savage. I had it on temporarily but like badboy, i was destorying my hand. busted the Pull start cable again and broke down and bought the steel cable one from this guy [email protected]
If you don't like how that damn cable is so close to the head I'd recommend buying one of his P/S. He makes the length of the handle a full 3.5 inches. This makes it easier to pull over as well, at least it makes it seem easier because you can better manipulate the handle and you can pull the cord while the body is on. My highest recommendation.
LEGENDARY if you are reading this thanks for that link to ebay that's how I found this guy.
Try it... it's worth the 56.00 delivered to your door. He got mine here in lightning speed. Two days after i paid it was at my door step.
hyper 8 port help
Originally posted by badboy2
man 56 bux is it guaranteed not to break?is it easy to pull ?and does it fits perfectly?
Needle Settings
Badboy, the settings from the factory are way rich. Almost too rich to keep the engine running. After much reading and a couple of calls to Ofna here's where my needles ended up.....
HSN 2.5 turns OUT from CLOSED
LSN 2 turns IN from FLUSH with the ball collar.
Also, you may want to check out Ofna's forums for some answers.
hyper 8 port help
Yeah - everyone has forwarned me about the cost of everything. Hoping I can do mail order. But then you have an xtra tax on everything coming into the country. It is like 18% or something. Correct me if I am wrong. Over all - I think the experience will be great for my kids and stuff. It is all good stuff.
hyper 8 port help
thanks - I will still be on RCU. I will be in Harrogate. They have cable modems there. Just will be off line for the 2 weeks on vacation and maybe 2 or 3 weeks getting settled in. The web site will stay up and I will make more vids over there.
Hopefully find me a good camera man to get my buggy on tape. I love that thing. I will be without my RC stuff for almost 7 or 8 weeks. It takes that long for the movers to get my stuff over there.
Good Times...
Good Times...
hyper 8 port help
Originally posted by gotskrilla
my brother has a hyper21 8 port for his 9.5 and this is what he did he just bought an ofna starter box much esier on the hands
GEE That's just frickin' fantastic. Too bad it WONT WORK ON A SAVAGE!!!
Tumbleweed
Glad to hear that it is working out for you with the P/S off Ebay! I had to change out my P/S a few weeks ago but, it was only the knot that came loose so I have a spare now!
gotskrilla, Tumbleweed is right! A starter box will not help anyone unless they have a buggy,truggy or on-road car! It won't work on a Maxx or Savage.
hyper 8 port help
Legendary,
Pretty sure you're the one that told me about that E-bay weren't you? Thanks alot I wouldn't have been able to find it without your direction.
Man I've got at least a couple hundred pulls on this one and it's showing no signs of letting out any time soon.
Though if I were wanting to do another one I'd just buy some of great planes or dubro's steel wire and do it my self. I didn't know that they had it for the push-pull systems on airplanes until a couple of weeks ago.
BTW anyone got a better way of rewinding my spring that doesn't take two people? I've done it four times on my latest 8 port and have finally fixed the problem of the spring popping out of it's retaining slip by fastening a small screw in place over the top of it <--- one heck of a run-on sentence.
Just interested in anyone elses techniques and it pertains to the 8 port cause it happens to alot of us <-I'm speculating
