Cant figure this out for the life of me!
NE
I am trying to use an XTM 24/7 for a replacement in my LST while "other" engine is being worked on. My question is they are both SG shafts yet I cannot make the screw tight on the clutch bell without making the clutch bell stop turning. I have put washers in every concevable postiion and still cant make the bell tight and still spin. I works on all my other engines.
Any help will be greatly appreciated!!!
RE: Cant figure this out for the life of me!
I had a similar problem while fitting my lrp30 to my savage,
to get around this i had to fit a slimmer flywheel nut,
when i tightened the cb screw on mine the cb would bind on the flywheel nut,
also check that your clutch shoes arent hitting the backside of the cb when you tighten the end bolt,
let us know how it goes for ya
