Best air filter? Savage
I've pre ordered a Savage SS and was needing the best possible air filter that money can buy. My truck will see nothing but fire roads and off road. I'm talking dusty! Money is no object, lol. I just need an awesome filter.
Also what about the K&N filters? Any good?
I've also seen a cold air intake on ebay. Looks like a good idea. But does it work.
Thanks in advance.
Thanks in advance.
VA
I am using a Motor Saver on mine. Works very nice. Never had a problem with any dirt getting through..Part#SAV90. I f you go this route, go with the HPI high perf though. It s the same exact filter, only about 6 bucks cheaper.
i hear paper filters suck, and K&N's arent the best for RC's (I have them on all my other vehicles though)
Motosaver or HPI High preformacne (same thing) gets my vote.
I use the motor saver filter, and i race in dusty conditions and my inner foam still clean. for the savage you just need an extra rubber coupler (ie by Gs racing smaller diameter) so that it reaches over the spur gear and inside the rollbar.
Will the current motor saver filter and J coupler work for the newer .25 Savage SS engines also? I haven't yet learned if most MT filters are interchangeable
VA
Yes it will. Airfilters are split into small and big block categories. The little angles and adapters are what you have to play with to get how you want it.
Well, I found the GS Racing J coupler.....maybe it'll save some people some searching
Head up to your LHS and ask for GS Racing part # GSMA15
"High Strength J Type Silicone Exhaust Coupler Small, for .12- .15 engines, 1 pc./ pkg. $4.99"
At first I was confused by the .12-.15 thing but then I remembered we aren't using this thing for the exhaust
k&n filters w/ a crome top are like 40 bucks from kustom r/c works
and i really like mine
i bought 3 and still have 1 in the package if u want it for 30 shipped
THE thing i don't get about K&N I love it in my real truck and i paid like 42.00 for it, I can't justify spending that for my savage and its like 1/32 or something the size, I'm sure they work great it does in my real car, but give me an 18.00 motorsaver and replacement foam for 1.99 and i can buy alot of foam for with the extra 22.00
scotthg1
it sure does make the engine breath a lot more cause of the added lenght of the J coupler it almost acts as a cold air intake.....
the j coupler is too long i would get one meant for an air filter the longer it is the less power you have.
i race 1/8 scale buggies and no one uses moter savers. everybody that is winning is using an RB.
bubbafien
bubbafien
I just used the one it came with and bought a hose clamp to keep it positioned off to the side. This way it can't rub on the spur of the pipe. Works fine for me.
The one I use on my savage is PART#GSCMA21BL THIS IS FOR A BLUE ONE......
Originally posted by bubbafien
rb concepts is the BEST you can buy, hands down!
bubbafien
bubbafien
