Exceed Tectonic motor trouble
Ive had my Exceed Tectonic for about a week and a half now. I thought i had it tuned pretty good considering the horrible instructions. Anyways i was driving it the other day and it just died at top speed. It will run up till top speed and die. ive been tinkering with the settings and cant seem to get anything to help. i have noticed that it gets an air bubble in the fuel line not sure if that would be the culprit. It will start, idle, and run very strong and quick up till it hits full throttle and dies. Im stumped, any info would be greatly appreciated! Thanks in advance!!
RE: Exceed Tectonic motor trouble
fuel comming from the exhaust pipe means the engine is lubricated and on the rich side.
seeing the truck is new to you, i guess you are also new to the hobby, so i would suggest going back to factory settings and tune from there.
also if you have bubbles in your fuel line it can be a couple of things,holes in fuel lines,fuel tank cap not sealing properly,air leak on the engine are the most common.
Impala
Impala
