MTA4 fuel tank issue
Hi all
Have started encountering a little bit of a problem with my Thunder Tiger MTA4 fuel tank. Basically the truck is cutting out about 1/3rd of the way through a full tank. Its fine for the first 1/3rd but then the engine cuts out and worse still, I cant get the fuel primer pump to suck the fuel through when the tank gets to this level.
There is no problem whatsoever when the tank is full though. The fuel pump primers sucks the nitro fuel no problem. Had a look inside the tank and I cant see any blockages.
Anyway all suggestions would be most appreciated
Cheers
George
Cheers
George
