Maxx 2.5 hop-up help
So I'm looking at my Tmaxx 2.5 and I want it to be a great basher, problem is, its Box-stock.
the engine is shot from sitting for so long with no break in and doesn't hold compression after it gets up to temp.
Im replacing it with a 3.3.
with that Im looking to do a Front only conversion
grab RPM arms all around
a single resonator tuned pipe
125oz steering servo
longer aluminum oil filled shocks,
but I dont know if I should get stronger RPM shock towers, or keep them weak so i break the shock tower rather than a shock.
or completely make them aluminum?
And there has been alot of people saying the stock tires on the Max arent bad if your just bashing
but i do mix it up and the street tears up the tire and grabs in all the wrong spots.
Any other upgrade ideas?
whats on YOUR 2.5? Anything will help thanks
