could you put a bigger......fuel tank...
fuel tank in the mt2?? if so how big??
RE: could you put a bigger......fuel tank...
You can, I am not sure how big. the 75 CC tank is plenty big though. I get pretty good times out of mine right now.
i see like 15 min? in each tank?
Thats fifteen if you run it dry. You can refuel it while its running, and have an infinite run time.
o really
Yup, I have done it many times.
good to know
that the plus abotu nitro unlimited run times as long as you have the fuel and the engine dosent over heat:D
how you stop it from over heating
Keep it tuned right, and keep the cooling head unrestricted.
You can run 5 - 10 tanks without stopping and it wont over heat if you tune right.
If you mean the CEN MT2 - CEN themselves put a bigger tank on to race. They had to modify the chassis a bit. Not sure exactly what they did. I am thinking of putting an air plane tank on my TMaxx. Bigger and when they flip the fuel line has a weight to keep it at bottom so it does not cut off. |
nice
all you really have to do is dril mounting holes for the fuel tank into the chassis, no big deal.
