Mammoth Or LST
Although there are many reviews out there for the LST it is still not on the streets being used by the general public.
But with the current reviews on the LST and the Mammoth I wonder which would proove to be the better truck to purchase. I ordered a mammoth already, but my bud wants to buy one as well and likes the mammoth but is thinking of pre-ordering the LST over it. |
RE: Mammoth Or LST
Neither! Go with Genesis! It's on sale right now at hobbytron.com. It's only 529.00. Look at all the stuff it comes with.
Features Aerospace grade chassis componenets Four Wheel Steering System with use of optional kit available soon. 4 Disk Brake system Special Engineered .46 Big Block Racing Engine Racing Tuned Pipe with high flow manifold Huge 7 1/2 inch Tires Full Precision Ball Bearings Special engineered Composit Drivetrain Ultra Gliding" Drivetrain" Composit, Light Weight Telescoping Drive Shafts and center shafts Dimension X 10 Coil-Overs System with Sealed, 3 fluids filled, low CG, Front, Rear and Center Differentials Convinent Pull start system Transmitter Controlled Reverse 3-Speed Automatic Transmission w/ adjustable shifting Adjustable toe/camber (Front and Rear) Large 220cc fuel tank High Impact bumpers (Front and Rear) Protected Radio Box and Battery case Adjustable Turnbuckles Final production specifications may vary from prototype drawing .46 Big Block Engine: 7.7cc displacement True ABC Construction Rear Exhaust Slide Carb 13 fins Giant Cooling head combined with special designed external engine block Massive wheelie pulling bottom end Torque combine with massive top end power Convient Pull Start system (Shaft start available optional) High Efficient Foam element air filter. Specifications Chassis and Transmission: Chassis: Aerospace grade material throughout chassis components. Brake: 4 Disk Brake System. Drive Axles: Special engineered composite, Light Weight Telescoping Drive Shafts and center shafts. Drive Train: Harden, Ultra Gliding Drive System. Transmission: 3 speed forward/reverse. Bearing: Full Precision Ball Bearings. Differential: Sealed, 3 fluids filled, low CG, Front, Rear and Center Differentials. Engine and Accessory: 46 Big Block Rear exhaust engine. Racing Tuned Pipe. High flow manifold. Fuel Tank: 220cc fuel tank. Electric/shaft Starting System (Optional) Wheel and Tire: High 7 1/2 inch tires. Chrome Spacious Wheels Suspension: 4 wheel independent suspension. Dimension X 10 coil-Overs system with 8 hardend adjustable Racing Shocks + Front and Rear dual center mounted shocks with reservoirs Electric: Newly Engineered. CEN Impact C3 radio system with metal gear high torque servos Front Suspension: Adjustable Camber. Adjustable Toe. Multiple Shock-mounting positions (including upper and lower suspension arms positions). Adjustable Shock mounts. Heavy Duty front Skid Plate. High Torque Servos Rear Suspension: Adjustable Camber. Adjustable Toe. Multiple Shock-mounting positions (including upper and lower suspension arms positions). Adjustable Shock mounts. Heavy Duty front Skid Plate. High Torque Servos. |
RE: Mammoth Or LST
Between the two I would go LST in a heartbeat. If it were open to any truck, I would go Revo.
They are all good trucks though. It really comes down to personal preference. You really can't go wrong. Get the one that has the best support from your local hobby shop so you can get parts and whatnot. |
RE: Mammoth Or LST
LST
RE: Mammoth Or LST
LST
RE: Mammoth Or LST
Thanks for all the positive feed back guys.
I think he's going with the LST over the mammoth. although the gen is impressivly BIG. Tweedy |
RE: Mammoth Or LST
ORIGINAL: Duff_Beer_12oz Neither! Go with Genesis! It's on sale right now at hobbytron.com. It's only 529.00. Look at all the stuff it comes with. Features (Available mid-June 2004) (FREE GROUND SHIPPING) |
RE: Mammoth Or LST
The Gen also uses inpresive amounts of gas :eek:
RE: Mammoth Or LST
yeah thats a con against the gen.
well we will sure see how the LST is. |
RE: Mammoth Or LST
I've never tried this before but i wonder if you can buy a truck, test drive it, and if you don't like it, return it.
RE: Mammoth Or LST
ORIGINAL: Duff_Beer_12oz I've never tried this before but i wonder if you can buy a truck, test drive it, and if you don't like it, return it. |
RE: Mammoth Or LST
You bafoon! You know what i mean!
RE: Mammoth Or LST
It was just a joke.
I assume you mean buffoon. If so then which definition do you intend: 1 : a ludicrous figure : CLOWN 2 : a gross and usually ill-educated or stupid person Honestly don't think I care for either one. |
RE: Mammoth Or LST
Ok thats enough. Lets stop there.
RE: Mammoth Or LST
Specifically, I don't think a hobby shop would allow that. I know that Hobby Town stamps all receipts "No Returns". I have a friend that used to own a hobby shop. He sold it because he said the margins are ludicrously low. On a $400 monster truck they make between $8-$40. It averages around 5-8%. Far too little to allow for a return of used equipment. I think the manufacturers ought to bring their stock to town for a "test-drive" day to facilitate this sort of thing. Very easy considering Horizon Hobby owns or distributes most everything in the market anyway.
RE: Mammoth Or LST
Getting off the topic...
