RPM two stage pistons
I'm going to use 2 stage pistons instead of the powerstroke shocks. I might get a new set of shocks if I can't fit them in the stock tnx bodies. Has anyone used them in the tamiya shocks, or has anyone bought some aftermarket shocks that they fitted with them?
Or just in general, has anyone used them and how to they work on the track? |
RE: RPM two stage pistons
I haven't used them, but they won't work with the TNX shocks unless you can find a different shock shaft to use. The stock TNX shocks have the piston built onto the shafts...all one piece. You would be better off using them on some Traxxas big bores or MGT shocks.
I used set @#80430,(the purple set) with the Rustler XL-5 stock all way 'round and it's "Perfect" for Bashing. Wow, RPM...has done it again!!!
