warhead 2 speed?
just got done breaking in my warhead, went through five tanks of 10% trinity break in fuel, everything is running smoothly, now im kinda bashing around with it, but I haven't heard it kick into 2nd yet, how fast do you have to be going before it kicks into second gear?
RE: warhead 2 speed?
It takes a while for that system to get running. Try running it wide open for a few seconds until it starts to work. If it doesnt work, do it again. If it doesnt after several tries, adjust the tranny (see manual)
alright ill try that tommorrw, thanks so much
The engine needs to turn a high rpm for the shifter to work. But there is a sound of the motor revs that you should here. If you look in the manual there is directions for adjusting the shift point. Always move the set screw it small amounts only. Turning the screw in will make it shift later. Screwing it out will make it shift sooner. Look in the manual and read it all first before trying it. Look on page 10 of the manual and if you don't have it download the manual from duratrax.com . There are 2 screws in there one lock the shifter 2 the shaft and the other one adjusts the shift point.
yeah i havent heard it shift into 2nd yet, unless i havent drove it fast enough yet lol
