Warhead Evo Receiver Question
HI my friend just got a new warhead evo and the batteries for the receiver and servos dont seem to last long at all. After only a few tanks of fuel the steering wont turn under the trucks weight and even the throttle response is delayed. Is there any thing that could be done? at this rate he will have to buy stock in a battery company....
RE: Warhead Evo Receiver Question
How about using rechargeable AA's?
Hi cdh9400t, do as guver said and go with rechargeables, I use lipos, buy a balance charger fo $15.00 and slow charge them, check all the servos and links to make sure that the servos are not working hard trying to move tight links, tight links and what have you will kill batteries real quick.
i'm using 6v 3000 nimh humppack battery, enough for fun,,and quick charger in hand is great to have too.
ORIGINAL: cdh9400t HI my friend just got a new warhead evo and the batteries for the receiver and servos dont seem to last long at all. After only a few tanks of fuel the steering wont turn under the trucks weight and even the throttle response is delayed. Is there any thing that could be done? at this rate he will have to buy stock in a battery company.... |
The thing that kills the life of batteries in the Warhead is the servo that controls forward/reverse. It's always active because it's putting pressure on the lever into the transmission. If you don't mind not having reverse, for a quick fix, I would disconnect that servo from the RX and cable tie the servo in place so that it is applying pressure to the lever towards the transmission. I did this until I ordered the forward-only shaft, and it worked great! =)
i have the same problem but i changed the batteries and the same thing,hard to turn or only turns one way, i found out if i losen up the screw at the bottom skid plate the screw for the servo saver i turns a little i realy dont want to lose the screw any tips,
ORIGINAL: gregmiller06 i have the same problem but i changed the batteries and the same thing,hard to turn or only turns one way, i found out if i losen up the screw at the bottom skid plate the screw for the servo saver i turns a little i realy dont want to lose the screw any tips, |
it seems everything is clean ive taken everything apart greased the shaft put it back together new batt and the tightn the screw and the same thing i dont know what to do this has never happened to me ive been driving nitro/ele for about ten years and never once happened any more ideas to try
i bought a orion hump pack and can blast around for hours it seems. Get 2 of thouse for around $30 bucks a peice.
another problem im haveing is when i give it gas my servo will flucuate back and forth should i change the servo or what do you think it iswhat should i do
