If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Oct 2006
    LAWTON, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    tt nitro bike with slide carb help
    ok i want to put in a new engine in my bike but the engine i want uses a slide carb instead of the rotary one so do anyone have pics of their's with that setup so i can see how to put the servos in to remount them if needed and also i have a digital remote and wanted to know it i can have a extra servo for break and one for throttle. thanks
  2. #2
    Join Date
    Nov 2008
    Kowloon, HONG KONG
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: tt nitro bike with slide carb help
    To change to slide cab setup my friend had done it before. Sorry I don't have any photo but you can refer to the Nuova faor setup. Placing both servo at the upper chassis. For braking usually people use a single servo for both throttle and brakes. But if you have a 3ch radio system you can setup an extra servo for it. Or use a Y-connector to connect both servos to ch2.
    All about R/C ehirobo
  3. #3
    Join Date
    Oct 2006
    LAWTON, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thank you.. so if i go with the Nuova faor setup what part will i need if you can help me with that also or do i just get Nuova faor servo mounts?
  4. #4
    Join Date
    Nov 2008
    Kowloon, HONG KONG
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just cut the top chassis out of aluminum or carbon fiber sheet. I am not sure if the NF top chassis will fit on the TTn. I know the steering support are almost identical. The only different is the TT have have an extra hole of the pole to hold the driver's hand in place. I will try to measure it tonight and let you know.
  5. #5
    Join Date
    Oct 2006
    LAWTON, OK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks for your help
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
