If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
Thread: What tires?
  1. #1
    Join Date
    Jan 2011
    , CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What tires?
    So i maged to pick up a 3s 25c 850mah lipo to go with the mamba 25 and 4200Kv motor and while I can get WICKED wheel spin, it just WONT lift the front tire. I know its got enough power, so I'm pretty sure its either a traction or gearing issue.
    Ive already got the aluminum gearbox on order, but I know I read here somewhere about running softer tires.
    I already removed the front wheel weight and have gotten used to having to carry alot more speed through the corners.
    Has anyone tried moving the weight to the back wheel and if so what was the effect? Or what effect do you think it would have?
    M.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #2
    Join Date
    Nov 2008
    Kowloon, HONG KONG
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: What tires?
    Try ZH tires, they works really good. And use the ZH hard front insert as well. For weight we had add some inside the rear wheel before. Don't really like it as it make the bike too stable..... very slow in corner. Try to add some to the bottom of the fairing. I added 60g and I know other had add as much as 100g to the bottom of the fairing.
    All about R/C ehirobo
  3. #3
    wayshwing's Avatar
    Join Date
    Jul 2006
    Santa Clara, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: What tires?
    What cycle is this for?
    If its for Kyosho HOR, you dont have to remove the front wheel weight.
    I run Venom soft compound tires on my HOR. I love them. They are rounder than the HOR tires, and softer, so you get mondo grip andmorelean angle too.
    You'll have to run Venom wheels as well, as they have the right beadlock for the tires. You can make Venom wheels fit the HOR by fitting the hubs with the right bearings. Look at pics of my HOR for example.
    Be sure to glue the tire to the wheel, especially the rear, to transfer power directly to the ground.
    Wayshwing
    RC\'\'ers can never have just one toy...
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
