LSN won't lean
LSN won't lean
My LSN is leaned all the way to the stop (clockwise) and still my engine is idling way too rich. It's a rotary carb. I've taken it apart, cleaned and reassembled it and still can't resolve the issue.
Any suggestions?
NS, CANADA
RE: LSN won't lean
If the LSN was truly bottomed out, no fuel would flow and the engine wouldn't run.
As you turn in the LSN, it's needle like tip inserts into the spray bar and eventually cuts off all fuel.
Sometimes the spray bar gets damaged from seating the LSN too tightly. It can leak fuel after that.
Some carbs have an adjustment for the spray bar and is sometimes referred to as the MSN. This may be way out of whack if it vibrated loose, or wasn't assembled correctly.
You might have your idle stop screw set so the carb doesn't close far enough, and the LSN might bottom out before it goes in the spray bar enough to get the right mixture lean-ness.
Turn your LSN out enough nothing is forced, and adjust the idle stop screw for about a 1mm opening when you close the throttle. Now gently turn in the LSN. Can you now lean the mixture?
RE: LSN won't lean
Thanks Argess,
you got me pointed in the right direction. The Idle stop screw on this engine actually guides (via a channel) the barrel back and forth while the throttle arm actuates. My idle stop screw wasunscrewed andnot making contact with the barrel. Therefore thebarrel was floating wherever it wantedand the lsn was never making contact with the splash bar.
I appreciate your guidance.
