Fuel for HPI Firestorm??
I have a question on this, as most people tend to run 16% yet the manual recommends 25%? Does it run better on 16% or what?
Thanks all
Thanks all
RE: Fuel for HPI Firestorm??
Are we talking oil content or nitro content? If its oil, I break-in on 14-16% oil and drop down to 12% for normal running. If its nitro, I run 20% all the time. The more nitro you have the wider the tuning window (sweet spot) it will have. Less nitro narrows your tuning window so the perfect tune is a little trickier to get depending on the engine. Less nitro is more efficient, since the needle is leaner. More nitro needs a fatter needle to compensate for the extra oxygen in the fuel (nitro = full of oxygen molecules)
Most engines will run just fine on 10% nitro, but most folks want a little more power so stepping up the nitro a tad will give more power. It comes down to how much you're willing to spend. The engine isnt going to care much what you run in it as long as it has some methanol and oil in it. If you're a good tuner, you could run it on 0-5% nitro too with a few easy modifications.
ORIGINAL: 1QwkSport2.5r
i thought it was easier with lower nitro?
i might be thinking RTR and race blended fuel!
When you mentioned 16%, I got confused because "standard" nitro percentages are 10%, 20%, and 30% for example. I haven't seen 16% nitro before, so thats why I questioned it.
iv never used 16% myself, iv seen it once or twice though!
used to use 10% about 10 years ago when i was young, i use 25% tornado now, its really good fuel just a bit expensive.
I was talking 16% like this:
www.modelsport.co.uk/modelsport-uk-performance-16-glow-fuel-1-litre/rc-car-products/29346
The manual for my Firestorm recommends 25% but it seemed a nightmare to tune on that. Kept cutting out and wouldn't start for ****. I have read loads so figure I am pretty clued up. Is it easier to tune the car when running a lower percentage of nitro?
thanks again guys
thanks again guys
ORIGINAL: Lewis.
http://www.modelsport.co.uk/modelspo...products/29346
thanks again guys
thanks again guys
Going from 16% nitro to 25% nitro would probably need the needles richened 1/4-1/2 turn to compensate for the extra nitro. More nitro = richer needles.
More nitro is easier to tune and adds power. If it revs slow and really smokey, its too rich. If it cuts out its too lean. The idle needle controls fuel mixture from idle to about 3/4 throttle, and the main needle (high speed) controls that last 3/4-WOT bit. Richen your low speed mixture a 1/4 turn or so and run a WOT pass or two to get the main needle set, then set your idle. Never set it the other way around.
ORIGINAL: Lewis.
thanks again guys
thanks again guys
Hi mate,
That's excellent thanks. So when you say the idle needle, you mean the idle needle and not the LSN (low speed needle?) Just checking - thanks for your help again!
ORIGINAL: Lewis.
Hi mate,
ORIGINAL: Lewis.
thanks again guys
thanks again guys
Hi mate,
The high speed or main mixture needle is in a fixed seat, unlike the idle needle. For this reason the main needle is always set first, and idle second. Some carburetors will not take a proper setting if the idle rpm is too high. Most of the time, low rpm mixture problems come from too high of an idle speed. Shoot for a idle gap of 1.0mm or slightly less.
