Jato stalls.
Jato stalls.
So I replaced the motor in my 3.3 jato, broke it in but now it won't stay running unless I stay on the gas. Always have to give it some throttle or it stalls. What do u think. FYI... Motor is another traxxas 3.3 and it's a new glow plug.
RE: Jato stalls.
ORIGINAL: Jato1229
I lean my idle down until it cuts out on transition to WOT, then richen 1/16-1/8th turn until it stops cutting out and throttles up nicely.
QC, CANADA
RE: Jato stalls.
Tune is off, but hard to say rich or lean video will help, but try resetting the needles, then make 2 1/8 clockwise adjustments to the high speed needle, see if that helps. Also insure your servo links work corect ie when you apply the brakes it doesnt close the carb more then when your fingers off the trigger. When you reset your needles reset the carb gap at the same time. Post up how that goes.
