RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
ae 15 stuck
Reply
Old 10-06-2012, 01:49 AM
sjhm9102
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ae 15 stuck
hi ae 15 rc10gt been sittin 5 years i got the motor unstuck now rope well rope doesnt want to catch the motor any help? thanks?
sjhm9102 is offline
Old 10-06-2012, 07:32 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ae 15 stuck
Quote:
ORIGINAL: sjhm9102
Pull the one-way clutch out of the pullstarter and clean it with either fresh fuel or denatured alcohol. Run a soft towel soaked with alcohol through the middle of the bearing and rotate the bearing either direction a few times to get the oil sludge loosened up. One-way clutches tend to slip if the needle bearings can't move or if they're too wet with oil. When cleaned out, install dry without any oil and it should work well. While the One-way clutch (bearing) is out of the car, look the outside over to check for cracks. If its cracked, replace it. They will slip if the outer housing is cracked.
Also, clean the starter shaft off really well with fuel or denatured alcohol and use some 400-600grit sandpaper to lightly "buff" the starter shaft going the long way. This will help the one-way clutch (bearing) to grip better.
Hope this helps you.
1QwkSport2.5r is offline
Old 10-07-2012, 07:20 AM
sjhm9102
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thank you that helps a alot i aprecciate the write up on that i just got back into rc i am a novice
sjhm9102 is offline
Old 10-07-2012, 10:13 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sjhm9102
Post back if that works for you and gets you going.
Old 10-09-2012, 03:29 AM
sjhm9102
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi i got the cover off and the rope recoil spool cameout with it how do i wind it back up set it .
sjhm9102 is offline
Old 10-09-2012, 08:30 AM
Big Alice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
   http://www.youtube.com/results?searc....1.kNw2g4pNNhU
Big Alice is offline
Old 10-10-2012, 06:49 AM
sjhm9102
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks i got it wound up but i have about 2 inces of rope hangin i will wind it tighter btw i was looking at the o.s 18 crv s with 11 j rotary carb is it a big difference in hp and speed thank you in advance
sjhm9102 is offline
Old 10-10-2012, 08:50 AM
controlliner
controlliner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sjhm9102
Huge difference in power, "wheelies". I put one in my T-Maxx and does it ever perform now!
controlliner is offline
Reply
Display Modes
