If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
  1. #1
    Join Date
    Oct 2012
    , PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    firestorm stalling problem
    ran my truck in the drive for 15 minutes till i had it tuned for the weather then i headed to the track, got to the track did a little tuning in the parking lot then through it on the track and after a minute it stalled everytime i went around a turn and braked at the same time so i tried tuning it a little then it got dark so i headed home, the track is very tight so i need to use my braks on it, i think it could be a throttle linkage adjustment or a brake adjustment as they do not stop it very quickly or it could be a combo of both. it got dark quick so i didnt have time to keep playing with it. any suggestions would be great its a hpi firestorm and its stock. its only about a year old and it runs like a champ in the yard and on the road.
  2. #2
    Join Date
    Mar 2007
    Quakertown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: firestorm stalling problem
    Thats ur carb. not being open enough. So ever time u hit the brakes, it closes the carb to far and the truck shots off. Get ur throttle trim set to 0 and then then turn ur throttle screw on the carb in a 1/4 turn in . Fire up the truck then hit the breaks. If it stay run n ur good. If not turn it one hr. at a time till it stays run n. check ur low end needle after that to make sure ur not to lean, try n to combinsate for the low idle. Hope that helps.
  3. #3
    Join Date
    Oct 2012
    , PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thanks man i got it all working good now i cant get it started i sent you a message asking you a question let me no if you got it thanks!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
