Hobao ST pullstart problem
Hi, need some advice.
replaced the pullstart, got macstar 28 one. had to also get the pullstart shaft as i misplaced it when i took the old pullstart off. shaft was stiff getting into the back off the pullstart. but now it is on the string gets stuck when pulling, if i unscrew the pull start case slightly i can pull fine but its all loose! any ideas?
