rc10gt problem
rc10gt problem
So i have a rc10gt with RPM a arms and CVD axles, the problem that im having is the axle keeps popping out while its running, in if your looking at the truck from the back you can tell that the left a arm is lower that right cause causing the axle to sit right on the end of the out drive. Ive shortened the shock as much as it can go and the only thing i can think of is limiting the down travel of the shock, but this has never been a problem till now. Ive been out of the RC game for awhile and really just getting back into because my son is old enough to drive them, and just got one for his Bday. So Id appreciate the help so me and my son can go drive them together.
RE: rc10gt problem
Make sure the rear arm mount is tight and not broken, check the bearings in the hub carrier. If those things are good, see what the shimming looks like. My guess would be that someone stacked all the shims on the outside of the carrier, and possibly left out the spacer in the hub carrier.
Are these 3/16" axles or 1/4"? If the latter, there is no spacer in the carrier because the bearings are flanged.
