RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Flywheel stuck after many years of no use
Reply
Old 11-15-2017, 02:34 PM
Frogozaur
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flywheel stuck after many years of no use
Hello, i have 2x Nitro RC cars, they have been laying for like 6~7 years, i decided to return to RC cars, i cleaned them etc, but i got a problem, On the one car the Flywheel is kinda thight but i can spin it with my hand, but it's still too tight to start up, on other one i need to use screwdriver and a lot power to push it...
What is the problem, is there a way to fix it without taking the motor apart?
PS. Sorry if i posted in wrong place, i'm new to forums and don't know what to do!
Thanks for help!
Frogozaur is offline
Old 11-15-2017, 06:28 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gummy dried oil. Put some fuel or acetone down the carb and glow plug hole. Let soak for a few minutes. Then take a hairdryer to the crankcase and it should loosen right up.
1QwkSport2.5r is offline
Old 11-16-2017, 07:05 AM
rgburrill
rgburrill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used air tool oil as an after run oil. It also works to loosen up a tight engine. I had one engine that sat for 10 years and wouldn't even turn over with the plug out. Poured air tool oil in it, let it sit for a day and it loosened up nicely. After that it ran like new.
rgburrill is offline
Old 11-16-2017, 07:54 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuel or acetone will have it free in minutes, not (a) day(s). Heat works wonders too.
Old 11-16-2017, 12:13 PM
rgburrill
rgburrill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuel? I doubt it unless it isn't very stuck at all. I tried fuel in the one that had sat for 10 years and it didn't work at all. Acetone might but it can destroy the seal. Air tool oil is cheap and works great. I bought mine at Kmart for $5 a pint and used that one pint for a couple of years.
I have used fuel in some gummed up engines that will turn over with a lot of force but that was before I found air tool oil. I tried Marvel Mystery oil first but air tool was a much, much lower cost alternative..
Old 11-16-2017, 02:30 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You have to get the fuel or acetone in the right places. Heating before adding solvent helps and can make a lot of difference. Not rocket science. Been doing this to airplane engines for years.
Old 11-17-2017, 04:03 PM
Frogozaur
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guy, in the end i took engines out of both cars, took out the part that covers piston and cleaned it all with Kerosene, both cars run very good now!
Thanks for help!
Old 01-01-2018, 04:51 AM
Smiff 24
Smiff 24's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad you got em freed up n runnin !
What kind of cars ya got ?
And welcome to RCU !
Smiff 24 is offline
