Official HPI MT2 Thread
RE: Official HPI MT2 Thread
what tooth would you recomed i get it was a 52 tooth one and what diffrence would a 47 tooth spur have compared with a 52 tooth spur
well first of all do u have engine mounts so u can move it around? and spur gear the lower the teeth faster it will go. and higher the teeth the slower it will go but u will have more power . if i were u i think i would stick to stock gearing but thats me so its up to u
TX
if you have the t-15 with out the hpi mounts the only spur you can use is the stock....with a 47t spur you will have more top end and with a 52t spur you will have more acceleration
ORIGINAL: lewis_lfc
TX
You need acceleration but always want speed lol
if u have the T-15 stick with the stock gearing
i WANT warm WEATHER
i hate running in the cold
i WANT warm WEATHER
GA
ORIGINAL: murawskiallen
ORIGINAL: lewis_lfc
http://www2.towerhobbies.com/cgi-bin...?&I=LXFPZ3&P=Z
http://www2.towerhobbies.com/cgi-bin...?&I=LXPC91&P=Z
http://www2.towerhobbies.com/cgi-bin...?&I=LXLZY6&P=Z
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXM693
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXGPA4
I used the above parts and built the CB using the 18ss instructions.
The first off road race of the season at hobbytown Columbus GA. was today. The weather was great sunny around 60 degrees,and the
attendance was very good. Didn't race the mt2 but raced the xxx-nt 2wd, will the mt2 the next race. 46u Cliff was one of the Macon racers who use to
race with us. A guy from Warner Robbins raced today.
TX
at least thats what he said im starting to think its eitehr a joke or its a CEN 7.7
he said he got it formm his friend and it has a 7.7
but o well he offered and he should come back to the store tomrow
i hope he was tellin the truth lol
NJ
if you dont trust him them tell him to bring the truck over so you can see the truck then fix it for him.. if i got into a deal like that i would wanna see the truck first be4 i did anything
GA
ORIGINAL: topcat-lll
GA
ORIGINAL: Hellacool
I upgraded my T-15 from the 12T CB to the 13T heavy duty CB from the savage and have had no problems. I ordered the bearings and cone washers for the 18SS and it dropped right on. Even passes the paper test.
ORIGINAL: lewis_lfc
GA
ORIGINAL: stadium truck freak
emmmmm i think venom racing do one
GA
46U what i ment to say was . what are the cheapest models of the savage as i am thinking of geting one?
TX
the guy im rebuilding for still has to buy the Piston and sleeve at my store
the venom pnboard temp monitors are a sad story
i think they are WAY to inaccurate and dont trust them at all
OR
i have a stock t 15 and i am ordering my os .18 cv rx at the LHS tomorro. should i upgrade anything else? i have the stock pipe, clutch, clutch bell, spur gear, axles, and diffs, actually everything but the fuel tank and fuel filter is stock.i just wanna order everything i need at once. thanks ahead of time
OR
also is this pipe any good for the os.18, and can i use the stock header? thanks
http://www2.towerhobbies.com/cgi-bin...?&I=LXCML7&P=Z
ORIGINAL: 46u
Yes I know Cliff and the guy over there today was Tony as I helped him with his MT 2 till 11:30 pm last night. I hear his diff gears went out and I told him months ago to get the heavy duty ones.
Tonight it popped out again, however the gear must have slipped when it happened and now the rear diff is clicking big time. I will take it apart tommorrow - I think I might just go ahead and order another set of the proper hardened diff/final gear for the MT2. The MT pinion is fine, but the way the diff cup secures onto it is a real weak point.
A real pain as well - the car was running so nicely! BTW 46u, when you shimmed the pinion what shims did you use? From memory you once posted up a link to a Tower Hobbies part number for those - this is one isn't it?
http://www2.towerhobbies.com/cgi-bin...?&I=LXTB43&P=7
o i thought venom stuff was good all tho i dont own any venom gear i herd good stuff about them at my track ? but they are a bit expensive . and guys you know the stock rims on the m2t can they be painted if u sand them down as i am thinking of painting them ?
if i were you you should definatley upgrade tha diffs and maybe a hardened spur gear.also you would get a lot more performance with a tuned pipe try the tsais rear pipe as a lot of people run it in this forum
ORIGINAL: dnizzle2
