RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Reply
Old 03-07-2013, 04:30 PM
  #21626
Arachna
Arachna's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Official HPI MT2 Thread
Thanx for the flywheel info Syco. I have a buddy with a savage, perhaps I will see if he has a spare flywheel I can test fit.
I am kicking around the pro-line flat iron tires. They are about 4 3/4 diameter instead of the Masher 5". They look good and may mean a bit less body surgery.
Arachna is offline
Old 03-08-2013, 03:06 PM
  #21627
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ejc34710
Well, right now i have a broke a arm in the front. Was just checking really, i need to start stocking up on parts for it before they start to get hard to find.
missed your post only difference's in the MT2's to my knowledge were the engine, and the material the diffs were made out of. I think the teeth on the diffs were even the same.
For the record the diffs should be going no where soon as the HPI Wheely king uses the same exact differential .
SyCo_VeNoM is offline
Old 03-08-2013, 03:32 PM
  #21628
ejc34710
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SyCo_VeNoM
Quote:
ORIGINAL: ejc34710
Thanks for the info, syco.
ejc34710 is offline
Old 03-14-2013, 08:08 AM
  #21629
Sam_shelton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys,
I am new to this board and have just got two mt2s as a lot on ebay. I have one up and running which is pretty much standard and the second one I am fitting lots of hop up parts to it since it had lots already.
Has anyone on here fitted gpm rear shocks on their mt2? I am having trouble getting them to fit because they are wider bore than the hpi ones and seem to touch the rear hub. Is there some special way of mounting them that I am missing or are they just poorly designed? I am using alluminium rear arms and hubs.
many thanks
Sam
Sam_shelton is offline
Old 03-14-2013, 01:52 PM
  #21630
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hmm I have the GMP towers, and from what I remember they were almost the exact same size as the stock.
take a pic of what you mean cause I might be thinking your issue is a little different then what I am imagining from what you said
Old 03-14-2013, 06:34 PM
  #21631
Sam_shelton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So here is the problem.
The GPM shocks have a larger diameter than the HPI ones.
If I mount them as the HPI ones were mounted they touch the rear hub: -
The only way that I can see to mount them is to put a screw into the arm, but the arms are not threaded all the way through just around half way through:
Has anyone else come across this problem? I can't seem to find any pictures of how other people mounted them and GPM don't provide any installation information.
Any help would be appreciated.
Old 03-15-2013, 05:31 AM
  #21632
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
blah dunno why I thought shock towers what I get for reading it when I am tired
odd does it do that with the stock arms?
I personally hated the aluminum arms as I found a few things to be outta whack(and after one whack they destroyed my rear hub)
Old 03-16-2013, 10:59 AM
  #21633
Arachna
Arachna's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sam, my only thought aside from your screw idea would be to find a longer shaft/hingpin that will give you more room to move the shock out.
Arachna is offline
Old 03-16-2013, 07:49 PM
  #21634
Sam_shelton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the suggestions. To be fair to GPM they replied to me with installation photos. It looks to me like the shaft that came with the arms was not long enough because the spacer should go between the arm and the shock to push it out and away from the hub. I have a longer shaft and tried it but the problem now is that they scrape on the inside of the wheel. The only solution to that problem seems to be having positive camber.
I think that these shocks are a no go. I am thinking that I will go back to the HPI aluminium shocks which seem to fit much better.
Apart from that the build is going well, photos to follow!
Old 03-18-2013, 03:00 AM
  #21635
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
don't extend the pin it will cause a whole world of troubles for you. try to get a shorter screw for the spot that you have it screwed into now that your best bet.
Jackedman is offline
Old 03-18-2013, 08:06 PM
  #21636
RCJuice
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just drill and tap the hole all the way through on the arm or if it doesn't go through (it looks like it may stay in the meat of the arm by your picture) just drill and tap it further in.
RCJuice is offline
Old 06-06-2013, 01:26 PM
  #21637
Arachna
Arachna's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Decided to "mini monster" my MT2 a bit. Put on some Masher 2k tires, 13tooth clutch bell and painted up a new HPI DSX-2 body for her. She seems to do well with the new setup.
Arachna is offline
Old 06-06-2013, 03:30 PM
  #21638
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good man
Old 06-20-2013, 11:34 AM
  #21639
Talk.Operated.Machine
Talk.Operated.Machine's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hehe this thread is huge!
I got my MT2 years ago when they first came out.. Modified it to the nth degree but then its been sitting in a box for about 4 years and i've only ran it twice lol
Such a waste, but i did enjoy building it...
There's a parts list here: http://www.rcuniverse.com/forum/fb.asp?m=4067694
I went mad on it lol.
Thinking of selling it if anyone in the uk wants a suped-up MT2 or knows a good place to sell one? Either that or ebay @99p lol
Talk.Operated.Machine is offline
Old 06-20-2013, 04:05 PM
  #21640
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oops
Old 06-21-2013, 02:55 AM
  #21641
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what wing mount is that???
Old 06-22-2013, 07:00 AM
  #21642
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Jackedman
The wing mount is home-made using plastic ball and socket joints with screws and rubber O-rings going through them. Tighten the screws to compress the rubber and it holds the wing firmly in place. If it gets knocked the wing has 4 points of articulation and can move freely on several planes . The idea was to make it crash resistant. I can get proper photo's of the assembly if you need...
Old 06-22-2013, 07:04 AM
  #21643
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One more with the shell on for your viewing pleasure
Old 06-22-2013, 07:07 AM
  #21644
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got told off yesterday for having the tyres on backwards
Old 06-23-2013, 05:40 AM
  #21645
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks man and who cares if you tires are backwards its your rig
Old 06-28-2013, 06:52 PM
  #21646
tattoodude72641
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey i have a problem on my mt2 g3.0 i have split my owb is there one that i can replce it with that might be tougher?
tattoodude72641 is offline
Old 06-29-2013, 08:40 AM
  #21647
Sam_shelton
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An update to my previous posts. I finally got the custom MT2 put together. In the end I decided to ditch the GPM shocks because they really didn't fit well and I go some of the HPI threaded shocks.
I ended having to raise the fuel tank up because the exhaust mount was underneath it. This was as a result of the OS engine having the exhaust port on the other side. I think the solution to this will be to fabricate a custom longer exhaust mount.
I just need to get the RPM sensor for the telemetry installed and break it in!
Old 06-29-2013, 10:55 AM
  #21648
SyCo_VeNoM
SyCo_VeNoM's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is one shiny ass MT2
I would personally go back to the plastic arms though as I had the aluminum ones on mine, and they caused a lot of issues like a broken pin, and breaking the part where they connect to the chassis off from a little jump. And that was only after maybe 15 mins of run time.
Old 07-01-2013, 06:59 PM
  #21649
tattoodude72641
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
that is one awesome setup ya got there!
Old 07-08-2013, 04:30 AM
  #21650
Jackedman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with venom about the arms, or maybe your not as hard on you trucks as we are. But it looks good and im glad you got the shock this shorted out
Reply
Display Modes
