Nitro Rustler vs MT 2
#51
MI
RE: Nitro Rustler vs MT 2
no the rs4 mt2 hpi it has 4wd and goes about 45 and its more durable and all i have to do is spend 85 bucks and i can get a wasp and the rus is fast but it cant get much faster than it is and it dosent have 4wd and it isnt as durable as the mt2 so i gess its just commen sense to go with the mt 2
#52
MI
Yea im all into monster trucks buddy, i got a savage.. I don't like the revo its gonna be fragile just like the t-max why dont u check the t-max out? You can't even drive that thing without it breaking.
And i use to have a electric rustler and broke stuff on it alot, nitro rustler is the same thing acept a diff chassic and has a engine.
You can buy titianium parts at rdracing and get them custom made. But i ment aluminum when i said that. I type 110 words per minute i make typos alot.
So you should really know more about what your talking about before u bash me.
#54
CA
ORIGINAL: Gordon69
the only thing that you can get thats not on thier site is red alluminum parts, and you have to order the whole set...
#56
MI
ok i no i want u guys to say either nitro rustler or mt2 if u were in my situation what would u get even if u do have a rustler would u get the mt2 still or not
#57
I have an MT2. It's a good truck for allround bashing. But don't expect it to go 45mph out of the box! It will be rather 35-40mph. But you can drop a .18 engine in and buy some other gears, and it will probably reach 45-50mph. I like this truck very much, but to be honest, I don't think you can expect anything more than 50mph. Also, if you would buy the truck, take your time to inspect the rear diff. There were some MT2's where the diffs were too loose, which caused them to be stripped fast. It takes 15 min. to inspect them and place an extra shim if needed. You'll be glad you took the time.
#59
OH
i got the rustler and mt 2..... i like the mt 2 alot better though, theres just not much you can do with the rustler cause it breaks when you jump it all the time. mt also has 4 wheel drive and has alot more torq and better acceleration but my stock engine on it only clocked 42 mph while my rustler clocked 51.. but i got a wasp 18 in my mt 2 now and it flys. but really it just depends on what u wanna do the rustler isnt much of a jumper or a basher its more like a speed truck while the mt 2 is the oppisate its a great jumper and basher and lacks a little speed
#62
OH
it would probly cost more to make the rustler durable cause i break alot of things on it. you would need alot of aluminum parts but i really havent looked into it cause i dont plan on wasting money on my rustler. but if u know where u can get some parts for it you will need to get all aluminum a-arm mounts, aluminum shock towers, aluminum front and rear a-arms, it will be quit expensive to buy these parts, alot of people dont like to engine in the rustler i would eventualy upgrade that too if i was you but you dont really need to do that right away
for the mt it will cost u probly under 100 bucks depends on what engine u get i got a wasp 18 for like 80 bucks at my lhs and you will need to regear it witch isnt expensive at all probly 15 bucks or so
#64
MI
skullbasher what do u have on ur nitro rustler to be able to take 8 to 10 feet of air off a jump. does it bottom out or not and if u have everything stock on a rustler and u take a jump and get like 6 feet of air will it bottom out/or worse yet brake the motor
#67
OH
isa it true that the mt2 only goes 35 to 40 mph
#68
MI
well skullbasher said he gets 8 to 10 feet just fine and what i mean by the moter breakin is will it crack or just not work any more
#72
CA
yea i do bottom out, and i also have to admit, i have some alluminum parts, and some home made strengthening on others, also have some rpm a-arms... accually i put some fuel line on the bottom of the shock shaft and it helps a little bit, but if your jumping high, there will be stress on your truck no matter what....
i accually have a hole in my crankcase, broke the mounting tab off the motor.... but i dont have to buy a new engine, just a crankcase... i think it got weak from when i landed upside down with my body off and my really tall cooling head on....
well you could crack the engine block if you are jumping on to cement or hard ground
#73
MI
on the axils ive read that you can higher them to even have a higher ground clearence than the mt2
#75
OH
no, if its all plastic it cant, well if u land perfect u might beable to get away with a few jumps and not break nothing but usualy you will. its really hard to control the rustler in the air too cause its only 2 wheel drive.. basicly if you dont land perfect you will break something every time
