Nitro Spray and Tires
One Word :- Excellent!
I've tried everything from alcohol to fairy liquid. The only thing that works best is Nitro Cleaning Spray. It blasts out dirt, dust, mud and everything else. Leaving it spik and span. No need for scrubbing spray and put it out side for a few seconds and thats it its evaporated and no dirt!
I Highly recommend it to people who play in mud alot like me. I have the HPI one so you could try some others.
One draw back though it's 4 pounds in Britain and it finishes after two BIG cleans (like everything and every where).
But if you road race with your car or even truck this stuffs great. Wash your tries with water and soap and scrub it. Dry it with clean cloth then spray it with nitro spray all over. Leave on tissues or cloth and after about 10 seconds its REALLY sticky the cloth won't STICK STICK to it but it will be pretty sticky and will give you better grip on the road. The thing was the tire wasn't even warm but it was sticky as hell.
Just my two cents but it might be a good idea for racers.
Reply with any thoughts.
RE: Nitro Spray and Tires
i like nitro spray too but, its bank and well simplegreen, or other type cleaners do just as good of a job, also use a air compressor. and a toothbrush.
ON, CANADA
ya thats all i use...a toothbrush and an air compressor..bascially you clean it off and then spray the water away and it takes the dirt with it.
i go mudding barely i've only went once it was pretty hard to go thru it with the stock tires but when it rains im gonna go bak out there with my mashers
i jus take the radio tray off my mt2 and clean it up and take the gas tank of the chassis and the engien and wipe it off and jus take the dirt off my engine and thats it
