Truck moves when I idle
NJ
I have a Factory Team GT and I'm running an O.S. CVR .12. I can't get the thing to idle properly because it always moves a little bit when my throttle is at neutral. I've messed with the idle screw and the throttle/ break linkage and I can't figure it out. Any ideas?
RE: Truck moves when I idle
I used to have the same problem with my RC10GT. I couldn't get it to idle low enough without stalling all the time. I finally got an MIP 4in1 clutch that cured all my problems. The engine can idle a little higher now with the truck standing still. That clutch works a lot better on the track too.
MD
ORIGINAL: mkimber
ORIGINAL: breakin2
TX
Your clutch spring may be weak from use and might need to be replaced, you can also use the adjustment on your brake to hold when your truck is at idle! There should be some info on how to adjust this in your manual. If you dont have a manual you should be able to get a copy online at teamassociated.com, hope this helps
J
J
NJ
I'm going to go for that MIP clutch. That sounds like what I need. I've fiddled with things so much that I've lost my mind. When I get it low enough to idle, it stalls a lot, especially when I hit the brakes.
ORIGINAL: breakin2
VA
ORIGINAL: dalosiman
J
J
MN
I use the stock shoes in my rc10 gt, and I like them fine. One thing that helps stop the idle creep problem is to install the shoes so that they are trailing, not leading. They slip more in the low revs in this configuration, but they seem to grab well enough in the powerband.
